Old 10-07-2020, 11:06 AM   #11 (permalink)
Piotrsko
In the sheet metal trade, we just made stuff thicker and used 120 grit sanding disks to grind off the high spots, but went looking and added bunches of filler to the low spots, sometimes making the part with filler everywhere. Straight bars with sandpaper stuck on for making stuff flatter. You may be able to do the same with your existing part if you can tolerate the new thinness which would be not much thinner (maybe .005 thinner).
Why not use the existing stick on emblem?
