Old 10-09-2020, 08:38 PM   #475 (permalink)
Xist
How about wall texture? That also has repair cans, but don't you end up with double texture?
Maintenance worked on a friend's plumbing and they retextured the wall above the toilet (but it was smooth behind the toilet and an inch or two around it).
It had a bad case of double texture. Someone that I watch regularly on YouTube said that the only way to repair texture is to redo the entire surface.
I always figure that if you tape off the original texture and blend the edges you should be able to make it work, but I have never tried.
