Old 10-10-2020, 02:45 AM   #9 (permalink)
serialk11r
Haha, happens to me too.
Looking at the diagram, it's a charge balancing only circuit, probably has a passive means of dissipating small amounts of energy, so I think you're fine if you connect the load to the charging directly. Effect is probably identical to putting diodes that burn off excess voltage, except in a nicer package that can be connected to a trickle charger.
