To answer your question though you might try the toned down top speed test. The throttle stop test. Just limit your throttle to (just guessing here) 50% and see what that top speed is. Then mod your car and re-test using the same limitations.
I am curious if this would be accurate over long periods of time. I wouldn't want to have to remove all of my mods and go back to a stock car to compare a new mod, so maybe you could collect some speed data and use that as a base forever, or just work backward from your previous change.
Then you can do the math to calculate the
change* in cd based on change in top speed.
I don't find the math very difficult to do, just need the data mostly.
*which means you would need a starting point to be able to say your cars cd went from .3 to .25 rather than 17%
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
