Old 10-11-2020, 12:54 AM   #67 (permalink)
JulianEdgar
Originally Posted by M_a_t_t View Post
Rules of thumb are guidelines at best.
Sorry, just reminded me of this scene.
The only way to know for sure is testing.
That's my take.
I think there is merit to comparing fuel economy increase to cd reduction, but not a steadfast rule. There is just so much that could contribute on different levels, for example bsfc for a different load %.
Expanding on that, the gearing at your selected speed is fixed, but your load would change. Which means your engine efficiency is now changing at a non-linear rate. Typically when compared it is something like "10% cd reduction = 5% fuel economy increase". Which is a linear rate change.
For example: A BSFC chart for a 1L metro engine
If your speed puts you at 3000 rpm and you lower your load (or required torque output) by ~30%, from 60 to 40, you can see it might be linear(ish), which might fit one rule of thumb. Then you reduce it more and now that first rule of thumb is inaccurate because of a different bsfc island. So now you would have to use a different rule of thumb based on the average of the 2, etc.
All good points.
But there's another major difficulty with the rule of thumb of a drag change = a percentage change in fuel economy, too.
Resistance to forward motion is made of rolling resistance plus drag. Rolling resistance hasn't changed a huge amount over time - or at least not like drag has changed. So if the rule applies to cars with (say) 0.45 Cd, how can the rule equally apply to cars with (say) 0.25 Cd? In the latter car, aero drag makes up a far smaller proportion of the overall resistance, but apparently a percentage change in Cd gives the same change in fuel economy?
M_a_t_t (10-11-2020)
