-Is the lexan easy to cut and bend (your roofed version was lexan wasn't it, did you have to heat it up alot or vacum form it somehow?) I noted that you said it scratched easily but do flies/bugs cause little cracks/fractures in the 'normal' screen you use or does the racked back angle limit such issues? my homebase liteglaze looks like its been in a humvee in Iraq.....
-where/how have you attached your fairing to the 90s frame?
-I've seen the fairings on that TGA site....scorchio!
m
