Originally Posted by extragoode
I've thought a couple times about using it as an injection mold in a plastic bag. Arrange plastic bag in hole you want filled, like a fog light hole, hold pressure on it until is stopped expanding, paint. A little trial and error with the amount injected would be necessary, but you would end up with a removable, perfectly shaped block if it worked like I think it should. I probably won't work that well, though.
I think that would work great! A lot of recumbant home builders have put foam in a plastic garbage bag to form "custom" seat mold.
