Old 10-18-2020, 12:08 AM   #5 (permalink)
freebeard
Let's go with the conflict thread. Maybe a moderator will delete this one.
Which thread? This one? A few days?
I think you underestimate what it takes for the mods muster one f-.
Still, I've railed for years against The Template as a Procrustean bed. I offered the superellipse as an alternative to the hemicircle.
The discussion I highlighted in ecomodder.com/.../interpersonal-conflict-subforum-38680-2.html#post633948 came from reverse engineering a hand-traced sketch, by one PK (), from a book. I propose a rigid mathematical framework to generate an aeroform, from a 5 or 6 frequency octahedral geodesic prolated 30/70 in the longitudinal and oblated 30/70 in the vertical axis.
As a motorhome it has a large window (Luigi Colani three-blade wipers) in front and skylighting in the living area. And a cute lil white cap.
Truncating The Template makes it more livable. Here's a diffuser that scavenges the underbody applied to a superellipse.
edit:
I need to figure out a graphical way of superlliptifying a geodesic. That involves combining Cartesian and Synergetic geometries. ???
And three synchronized three-blade propellors on overlapping hexagons would be Steampunk.
What the headline giveth, the last paragraph taketh away. -- Scott Ott
