It would fail. The refractive index would make it opaque at that angle.
It's meant to be horizontal
* so you don't look through the material at all when looking straight back, only if you were looking backwards sideways in the silly way, would it be in the way.
*) Nearly, you could make it the same angle as from you eyeballs to wherever on the rear window it starts.
![](http://ecomodder.com/forum/member-jakobnev-albums-signatures-picture7557-signature.png)
