Old 10-20-2020, 02:02 AM   #358 (permalink)
redpoint5
90 day: 38.47 mpg (US)
Originally Posted by serialk11r View Post
All the capacitor balancing circuits I've seen just use a voltage regulator or LEDs across individual cells, that one appears to do the same. In that picture, you can see those red wires going down to the bottom, so I think there are 6 boards total.
The most ghetto thing you can do is use diodes and resistors across the terminals, but I feel like these days when you can get inductive active balance circuits for 10 dollars, you might as well do it properly.
And yea I think not pushing close to the max voltage is a good idea. 6 in series leaves some comfortable margin which should help the electrolyte last longer.
I bought a 4s balance board that moves high charge to the lower cell for my LiFePO4 battery. It kicks on whenever the voltage differential exceeds 0.1v.
I inquired about this balance board to see if it would work for ultracaps, but apparently not. I'm not finding anything else except the boards I posted above.
https://www.amazon.com/6Series-Lithi...6R4PA75ME4K544
