Old 10-22-2020, 10:51 PM   #6 (permalink)
ksa8907
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
Originally Posted by arcosine View Post
Installing the gears backward would reverse the thrust, not sure of the outcome. The Intrepid uses the 42TE transmission, a longitudinal layout that does not use these transfer gears, it uses a chain and sprockets.
42LE, but yes. The picture of the cover and gears looked awfully familiar. What I meant by backwards is, input gear on output shaft and output gear on input shaft. It was possible on the 42LE, not sure about your 41TE.
Good luck.
