Old 10-23-2020, 09:02 AM   #345 (permalink)
Piotrsko
Well, the fast way to decide is to put air under pressure into the cylinder through the plug hole and listen where the leaks come out. Breather means rings, intake means valves. I would bet rings in your case because I havent seen a comment regarding oil puffs on start up which is the traditional telltale for valve guides /seals.
The Following 2 Users Say Thank You to Piotrsko For This Useful Post:
elhigh (11-18-2020), MetroMPG (10-23-2020)
