Old 10-23-2020, 12:12 PM   #364 (permalink)
hayden55
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
Originally Posted by teoman View Post
You are right. But coupling the caps to a battery also has voltage problems.
A lead acid sits at 13 ish volts. So you are essentially wasting delta 3V.
In my un investigated case, the capacitors are not sufficient to start the vehicle (i probably need to do a better connection to the capacitors). I am thinking of a small boost converter to top the caps to 16V for startup.
Didn't mazda solve this with programming in dedicated circuits/timing for the start stop regen portions?
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
