Old 10-23-2020, 03:02 PM   #52 (permalink)
aerohead
another 20 MPH
Originally Posted by Angel And The Wolf View Post
Was the 5th edition written when the National Speed Limit was 55 MPH? Another 20 MPH should mean a more gradual taper.
Technically, once the supercritical Reynolds number is reached ( around 20-mph ), the drag coefficient will be constant up to around 250-mph, when compressibility effects of transonic flow comes into play.
The 22-degree threshold is from W.A.Mair's research of 1969. Buchheim et al. went as far as 22.5-degrees on prismatic bodies, when the aft-body constituted 45% of total vehicle length. It's very conditional.
Both limits are effective only if the appropriate 'run-up' contours are respected.
If we had a 'true-length' plan-view image of the trike, taken from above, it would give us much-needed information.
The shape defined by the sweep of an analog clock's second hand, between 12:00, and 4-seconds after, provides the proper run-up.
