The claims of an standard ICE only using less that 30% of it fuel to make power and wasting the remainder of the raw gas poured into it is well known. The left over only produces heat that the cooling system must handle.
The theory is IF fed 100% gas vapor it would only need about 20 to 30% of its normal fuel.
So take a car that gets say 30/40MPG and run it on vapor at say the insane 20% of its normal GPH and you have a 100+ MPG car, with out all that body work and so on.
Rich
