1937 Ford would be the one year only tube axle. Racer's found that the round axle and the I-beam with lightening holes had similar drag.
By welding steel that I shape and/or that's already shaped, such as body parts from cars.
Pie cuts. It's surprising how far you have to cut to get a smooth curve. Curved edges instead of straight ones. (Can't find an example pic) The best VW top chops have the B-pillar cut a fraction of an inch less than the A and C-pillars. This forces the B-pillar into a better curve.
Like a drive axle boot or an articulated bus. The axle experiences pitch and roll, the radius rods constrain yaw. Fillets are much better than gaping holes.
I like the other geodesic one you post that has a greenhouse.
It was supposed to have a similar windscreen, that was a Gurney bump for your head to bounce into. I haven't posted these in a while. They date from mid-1990s:
Here's a Westergard-style Messerschmitt:
![](https://ecomodder.com/forum/member-freebeard-albums-photoshops-picture4841-4268563897-70e274f888-z4.jpg)
