DPF trucks are an illusion. They still put out plenty of soot it's just the soot they do make is 1 to 2 nano meter so you can't see it.
My carburetor suburban smells like fire crackers as its set up for lean idle and lean burn.
You can't chip a diesel that isn't computer controlled. Are you really that dumb?
https://www.greencarcongress.com/200...of_contin.html
https://ecomodder.com/forum/showthre...ncy-21437.html
We can only spoon feed you so much, at some point you need to lean how to do your own searches.
