Originally Posted by JSH
Yes, the exhaust coming out of a DPF filter isn't completely soot free. However they do significantly reduce the volume of soot. The idea is to take carbon + O2 + heat to make CO2.
And that heat comes from fuel injected directly into the DPF and wasted. The first generation of ford DPF used up to 17 liters to do the regeneration cycle. 4 gallons of fuel, just poof.
