Old 11-03-2020, 06:57 AM   #5 (permalink)
Tippaleipa
Yes, i changed the d15z1 engine harness too and repinned shock tower connectors. I drove the donor vehicle about 60miles and it worked like it should, it doesn't have ELD either. hmm about that map sensor, d15z1 uses TB map sensor but it was connected before to firewall mounted map. Now it is connected to TB sensor.
I installed two new ground wires, one to gearbox and one to engine itself and measured ground from o2 and it was 0.0 ohms. I have also checked tps wiring and it is correct and no codes from tps.
And there is also that when its cold like 5 celcius, outside, car doesn't start on first try. cranks but no start. i tried prime the fuel pump few times but still, no start. Second crank and boom purrs like kitten.
