Originally Posted by Piotrsko
The anti icing systems are rubber boots that inflate to rupture the ice bond so it slides off in the slipstream.
The boots system is for de-icing, and usually found on turboprops, but it won't prevent icing as the heating systems usually fitted to jets do. If the pilot turns the de-icing boots on before the icing starts, it becomes uneffective as the ice would accumulate around the inflated boots and then they won't be effective to remove them.
