Old 11-03-2020, 10:35 AM   #15 (permalink)
samwichse
Thalmaturge
CHONK - '18 Honda Clarity
Originally Posted by jakobnev View Post
This is cool! Check out the specs, too. Pretty decent:
Transportel <www.transportel.se> elmopeder, elodrive & eldrivna fordon
Motor Powerful high efficiency permanent magnet motor with four carbon brushes to ensure a long service life. Power 1,5 kW. Max power 3,5 kW / 1 min.
Speed control Electronic, continuously variable forward and backward. Max output 200A. Choose between hand or foot controls. All other controls are placed at the handles.
Security Safety switches in footrest and charger inlet.
Charger Built-in full automatic 230 / 24 V, 20A with maintenance charging.
Charging time 12 hours after 80% discharge.
Battery High quality tubular plate type. Capacity 175 Ah / 5h, or 110 Ah / 5h.
Transmission Duplex chain to rear wheel.
Brakes Disc brakes on all three wheels. Foot brake with two independent hydraulic systems. Automatic parking brake on rear wheel.
Tyres Front 4.00 x 8 – 6.P.R.
Pressure 3 bars.
Rear 4.00 x 12 – 6.P.R.
Pressure 4 bars.
Suspension Rubber shock absorbers on front sub-frame. Adjustable saddle rod with spring suspension.
Speed 20 or 25 km / h.
Driving distance 30 - 80 km / day, depending on driving conditions and battery capacity.
Dimensions L = 2580 mm, B = 1000 mm, H = 1060 mm.
Load capacity L = 1200 mm, B = 1000 mm.
Weight 295 kg.
Max load 270 kg.
