Old 11-06-2020, 12:15 PM   #46 (permalink)
aerohead
specs
We need:
* overall height at maximum suspension extension
* 'normal' suspension height setting?
* a long distance, telephoto image for all views, or a set of technical drawings
* curb weight
* top speed ( and whether that is 'drag limited' or governed )
* an actual road test result for a given speed ( like Motor Trend has provided for other BEVs ), not EPA dynamometer cycles
* actual range from actual road test
* Cd would be great!
* frontal area would be great! ( although could be ascertained from a technical image )
* tire manufacturer and precise tire specifications for each of the two available tire sizes
* single planetary gearset on motor?
Moving footage of the HUMMER at speed exhibits a wake larger than the vehicle itself. Very disturbing!
