Old 11-08-2020, 03:30 PM   #3 (permalink)
cRiPpLe_rOoStEr
Even though a vacuum gauge is often reporter to be more useful in a carburettor-fed engine, while it doesn't seem to make so much sense on newer EFI systems due to their electronic throttle bodies which position doesn't have a fixed ratio for each RPM or throttle pedal position, I remember having seen some fitted to vehicles which already had an EFI even though the throttle body was linked to the pedal through a cable.
