Old 11-10-2020, 05:47 PM   #3 (permalink)
CigaR007
CigaR007's Avatar
GreenTurtle (Retired) - '01 Toyota Echo Sedan
90 day: 44.85 mpg (US)
Zulu - '14 Honda CR-Z
90 day: 49.05 mpg (US)
Go with a camera that has a built-in display as it will allow you to instantly confirm that your camera shot framing is optimal for the desired task.
My current setup (1st gen. GoPro) involves recording-removing SD card-validate framing in laptop-adjust framing if needed - THEN I can proceed with recording the actual video. Very time-consuming.
I believe newer generation cameras can broadcast the video feed to your smartphone via WIFI; could be handy if you want a "live" feed.
The Following User Says Thank You to CigaR007 For This Useful Post:
Cd (11-13-2020)
