Old 11-11-2020, 07:20 PM   #36 (permalink)
Grant-53
Here in Upstate New York we are very familiar with driving in deep snow. A smooth under carriage with at least 9 inches (230 mm) of ground clearance is recommended. A radiator block system is good and a modest chin spoiler of rigid material is helpful. Controlling the air flow over the roof and rear window is important. Ice build up behind the tires is common. If one gets stuck it is important to be able to clear snow away from the wheels and put down some type of traction material. Also remember the top speed will be less in winter conditions.
The Following User Says Thank You to Grant-53 For This Useful Post:
JacobLeSann (11-11-2020)
