Old 11-12-2020, 04:59 PM   #49 (permalink)
kach22i
Originally Posted by JacobLeSann View Post
If I’m already set on a wing, why don’t I carry the sides down and make a partial Kammback? Or does it not help? Thanks in advance for any clarification.
I'm confused, so I will post some images to go with certain terms of phrases.
Box Cavity:
https://ecomodder.com/forum/showthre...k-26367-2.html
https://ecomodder.com/forum/showthre...uck-26367.html
Kammback
https://www.metrompg.com/
https://ecomodder.com/forum/showthre...oat-24419.html
Wing
https://www.carid.com/duraflex/custo...r-spoiler.html
Rear Spoiler: Bonneville-style rear deck extension
https://ecomodder.com/forum/showthre...any-10434.html
Not to be nit-picky but words can mean one thing to one person, and another thing to another person.
A wing is up and into the airflow, a spoiler interrupts said flow, a Kammback is like a fastback only more so because it maintains air attachment and isn't just a styling statement, and a Box Cavity may overlap with several of the preceding terms but in short distinguishes it's self with an absence or negative space.
It sounds like you want to build a "Box Cavity" and should call it that.
Not as exciting sounding as a "wing" but that's the marketing department's problem.
You could say your Box Cavity is an open ended Kammback if it's like that white VW van - the very first image.
Everyone would be quite confused until you post a picture though.
The bottom image is a rear spoiler, box cavity and has vertical wing stubs (stall fences if on aircraft).
Now I'm back to being confused?
The Following 3 Users Say Thank You to kach22i For This Useful Post:
COcyclist (02-17-2021), freebeard (11-12-2020), JacobLeSann (11-12-2020)
