Old 11-13-2020, 11:00 PM   #23 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
Yes they clear cut, then the lumber company has 2 ways they grow it back. 1 way is just leave a few mature seed trees behind or replant saplings in rows. Either way everything grows back like crazy for about the next 6 years, trust me all the forest critters want to hang out in the young forest when everything is between 3 and 8 feet tall. Then at some point foresters come in and thin it out so the lumber trees can grow. They repeatedly come back and remove undergrowth.
Also trim the lumber trees so they grow straight and produce higher value wood.
You must be walking through different forests than me.
Yes, timber companies clear cut - and leave all the trimmings on the ground which dry and become fuel. Yes, they replant - which leaves a thick forest of small treas that easily burn. Yes they come back trim and thin when the trees get bigger - and leave the trimmings on the ground which dry and become even more fuel.
During the recent wildfires in Oregon the fires burned right across timber clearcuts on private land and on to the forest on the other side.
In 2018, a study co-authored by Christopher Dunn of Oregon State and Harold Zald of Humboldt University examined the 2013 Douglas Complex Fire. They found that weather was the primary factor in determining fire severity but concluded fire severity was greater on private plantations than in older public forests.
https://www.eugeneweekly.com/2020/09...ng-the-flames/
And the study.
https://www.emwh.org/issues/habitat/...0landscape.pdf
