Old 11-17-2020, 02:11 AM   #4 (permalink)
freebeard
Is It Worth Sharpening Circular Saw Blades? How to Sharpen?
https://www.finepowertools.com/saws/...ar-saw-blades/
Cost of Sharpening Circular Saw Blades You can either sharpen the blade yourself or have a professional do it for you. Although the cost will vary depending on the quality, size, and material of the blade, you can expect to pay from 25 to 50 cents for every tooth of the blade that is sharpened.
Back when I worked construction I used a certain saw shop all the time. After I'd changed careers about 25 years later I took a few in and the guy remembered my name. I'd known he had a phonographic memory, but it still freaked me out.
