Old 11-19-2020, 01:49 AM   #111 (permalink)
JulianEdgar
How do you get from measured pressures to significance and action? Panel orientation to direction of travel? How do you generalize that?
Car aerodynamic pressures develop forces that act at right angles to the panel. You can then use the 'triangle of forces' to work out the magnitude of the drag/thrust and lift/downforce.
To understand its significance, the force is then multiplied by the area over which that pressure is acting.
I've done lots of videos.
The Following 2 Users Say Thank You to JulianEdgar For This Useful Post:
freebeard (11-19-2020), woodstock74 (11-19-2020)
