You know, being such a gearhead, I shouldn't have just accepted the stats below even if it is from a PCA page. I knew better. V
http://vista.pca.org/stl/index.htm
Specifications for the 1970-76 914-4
Engine:
Horizontally opposed flat-4 cylinder, mid-mounted 1.7, 1.8, or 2.0L engine
Bore and Stroke: 90x66mm; 93x66mm; 94x71mm
Displacement:1.7L (1679cc); 1.8L (1795cc); 2.0L (1971cc)
Horsepower: 80 (1.7L), 79 (1.8L), 95 (2.0L)*
Compression ratio: 8.2:1 ; 7.3:1 ; 7.6:1
Cd:
Fuel system:
Drivetrain:
5 speed manual transmission
Suspension:
Independent front with lower control arms, spring struts, anti-roll bar
Independent rear, with semi-trailing arms, transverse torsion bars, anti-roll bar
Dimensions:
Curb weight: 2,892 lbs
Wheelbase: 94.5"
Length: 170.9"
Width: 68.3"
Height: 50.2"
Track front/rear: 58.2"/57.1"
Ground clearance: 4.9"
