Old 09-26-2008, 06:59 PM   #322 (permalink)
metroschultz
metroschultz's Avatar
CPT SLO - '93 GEO Metro plainjane
90 day: 53.91 mpg (US)
SilverHairBeauty - '01 Toyota Avalon XL
90 day: 24.06 mpg (US)
Send a message via AIM to metroschultz
30 years listening to people describe their problems..........
Originally Posted by MPaulHolmes View Post
I don't really know the parts I need. I do know that when I move the wheel (off the ground) at 9 and 3, there's an inch of play that happens at a rubber joint thing. It's pretty close to the wheel. There's a metal bar from the wheel to the rubber joint thing. Next, I probably should buy a new steering damper (I think it's called that). Basically, I have no idea what's wrong, and I just want it to not shake violently at 35 mph.
Lead me to believe you are describing an
Outer Tie Rod End
It is easy to replace. (and you already have a repair manual)
You will need to get a front end alignment after you replace it.
With all you have accomplished so far this will be a cake walk for you.
S.
When you are courting a nice girl an hour seems like a second. When you sit on a red-hot cinder a second seems like an hour. That's relativity.
Albert Einstein
