Tps has the +5v, signal comes to ECM and also has sensor ground. I dont have the egr control box so the vacuum to lift valve is blocked and it throws code 12 which is egr lift valve. Engine worked great in donor car without egr so i ruled that out. This lean burn bog/misfire seems to be common problem with these things.
