Old 11-25-2020, 02:05 PM   #127 (permalink)
aerohead
never mentioned
Originally Posted by JulianEdgar View Post
Out of interest, I had a look in this book to see its coverage of 'basic low drag shapes'.
There are just two pages on this topic - in a book of a little under 1300 pages!
As far as I can see, these shapes are never mentioned again - and certainly are not used for any of the following purposes:
- Show where there is separated and attached flow on existing cars
- Guide the shape of rear extensions
- Show how rear spoilers on sedans should be positioned and shaped
- Allow the assessment of the ‘aerodynamic purity’ of cars
In the real world of road cars, basic shapes like the template are pretty well irrelevant.
In the Preface of his 2nd-Edition, Hucho admonishes us, advising us to learn everything about road vehicle aerodynamics, plus that from other disciplines, such that we may draw on the entire body of knowledge to draw on for solutions.
You'll be in an information desert unless you've explored biomimicry, airships, blimps, blisters, canopies, fairings, radomes, bullet-valves, nozzles, self-powered rail-cars, submarine exterior hulls, torpedoes, projectiles, belly tanks, drop-tanks, towed electronics arrays, antenna housings, etc..
If you'll continue to learn, you'll eventually arrive at a reality which overturns your present rudimentary understanding.
' It ain't what you know, it's what you think you know that just ain't so.' Mark Twain
