Old 11-26-2020, 02:57 AM   #1 (permalink)
eagle
eagle's Avatar
rozy - '09 Ford Fiesta Zetec S
Magnehelic gauge measurements
I am not sure if this or the "instrumentation" thread is more appropriate so mods please excuse me
I just had a morning drive to check if my magnehelic gauge was working and to start I checked if my oil cooler was receiving any air ; being behind the front bumper and only a small corner facing an opening
two 4mm tubes were installed one in front of the oil cooler and one behind facing downwards, then through a very small opening in my passengers window
results: With both high and low ports connected the gauge was showing 0, zero , nada , nothing
it added to my speculation that I had bought a faulty gauge. So I disconnected the low port and behold! 80 pascals
connected it again and dropped to zero again. removed it again and raised my speed from 80 to 100 km/h and was raised to 90 something
then for a final treat I tried opening the window to see any influence. and yes, once I opened it it went from 90 to 100+
so to sum up: does this mean my oil cooler does not receive any fresh air? it does but relative to the inside of the cabin (low pressure area? ) ...uhm....dont know
since this was my first measurements please be kind. I would also like to measure my water radiator, intercooler, and also hood pressures with this method but I am not sure what to expect
read a book of a member in here but I just want to be sure what I actually saw the gauge do
shorturl.at/fhpq0
