Old 11-26-2020, 02:03 AM   #2 (permalink)
JulianEdgar
If the comparison was before and after the oil cooler, and the result was zero, then yes there is no airflow through the cooler. (The cabin pressure is not relevant unless a gauge port is open to the cabin - not required in this case.)
It's amazing what you find when you do some measurements!
Now, how to fix the issue. Perhaps some pics of the installation so some suggestions can be made?
