Old 11-26-2020, 10:34 AM   #139 (permalink)
AeroMcAeroFace
Long time lurker
AeroMcAeroFace's Avatar
You haven't said a thing! Did you read the two pages? Maybe just throw away the other 1298?
Next time you two visit, ask him about the XL1. And why VW chose that form.
I must have done this wrong then. I have tried quite a few times though. I think template wisdom would suggest reaching up to the template to get lower drag.
They must have separated flow all the way down the back.
"Aerohead, I think you mentioned something about the tumblehome playing a large part in keeping flow attached once the rear glass goes out of the curve of the template." Flow is 3d, there are C-pillar vortices that can cause the flow to attach. However it is not always the result of C-pillar vortices, the EV1 had a lot of attached flow from the side of the car going over the back window. I would think that the XL1 is the same.
The Following 2 Users Say Thank You to AeroMcAeroFace For This Useful Post:
aerohead (12-02-2020), JulianEdgar (11-27-2020)
