Originally Posted by AdrianD
There are drain holes on each side of the jacking points on the rocker seam. Too bad everybody closes them, then the rockers rust from the inside out ![Mad](/forum/images/smilies/mad.gif)
They just fill up with debris, a thin wire will open them up. I managed to collect over 2 gallons of water from the rockers one of my miatas. You will want to check the drain tubes behind the seats, the drains in the doors, and pull the rugs..the fiber matting under the rugs can hold ten pounds of water, easily.
