Originally Posted by JulianEdgar
Can you give us a guide as to:
- what facilities you have to make modifications
- your background in car modification
- the amount you're happy to spend
Otherwise, it's easy to make suggestions that are of no help at all.
- I dont have much at the moment besides basic tools for maintenance and enough space to work on the car freely
- I have no prior experience with car modification
- I wish to spend less than $600 to start. This is for both parts/material and tooling. I do plan on eventually engine overhauling/reboring (or swapping), and replacing the current 5 speed with that of an HX from the same generation. However I won't worry about that or its cost for a year if not more.
I will update the original post to include the link to the car once I have made the 5 post quota as a new member. The link roughly outlines the work I hope to do on it.
