Old 12-02-2020, 12:02 PM   #547 (permalink)
kach22i
Porsche 550 Spyder factory drawings | SMCars.Net - Car Blueprints Forum
Can anyone translate the German above?
What is Cw, is that like Cd but in German?
Cw = Cd ?
CwF = CdA ?
ST-Classic
https://www.st-classic.com/
ST-Classic
Not shown is the fuel pump and brake pedal line junction cover plate (deflection plate) between the ST-Classic skid plate and floor pan. Would make for a fairly flat surface minus the chaos of the air being passed over the cylinders at the rear (right side of image).
My deflection plate had several dents in it that I flattened out with a 3lb hammer. It's there for a reason, you don't want to lose your fuel pump to a Michigan pot hole.
NOTE: I'm not sure why ST-Classic chose images of a 550 and 356 for a 911 spare tire hold down strap. If it looks confusing, it is clarified at the site with other images - I trust.
I have not taken the very top image to the aerodynamic template AST-II or otherwise. Could prove to be interesting, but looks to fall way short. If the Cd is 0.233 that would be awesome.
COcyclist (12-03-2020)
