Old 12-02-2020, 05:17 PM   #8 (permalink)
aerohead
definitions
Originally Posted by JulianEdgar View Post
When Aerohead is wrong, he simply changes the definitions of words. We've seen it before (attached flow isn't really attached low if it doesn't match the template) and now a Nissan Leaf is fastback.
It's a fascinating world where reality can be altered to fit belief.
So, why don't we work it out. You have Hucho's 2nd-Edition. You know that he basically said that 'fastbacks' are the only real path to low drag.
If that's the qualifier, then the LEAF is a roof-truncated fastback. Adding the 'elongation' to achieve the lower drag would visually drive the message home.
Like the 1978 Daimler-Benz, Mercedes-Benz, C-111, III, in three flavors: Cd 0.237 to Cd 0.178. Depending on length.
