Old 12-04-2020, 04:20 PM   #241 (permalink)
aerohead
doesn't know
Originally Posted by JulianEdgar View Post
Aerohead doesn't know what Coanda Effect means when applied to road car aerodynamics, won't look at the references I have given, denigrates a professional aerodynamicist who uses the term correctly, and then goes off in his own world of irrelevant musings.
Not very helpful, to put it mildly.
Out of courtesy to Freebeard, I made an effort to acquaint myself with the work of Henri Coanda over a decade ago.
Nothing Coanda did dovetails with anything you've said, or attributed to Dr. Wolf's treatment of the subject. Your words betray a complete void of knowledge pertaining to Coanda.
I don't consider that you're in command of any value-added information which would offer applied technology to anything members might undertake.
You take on the air of someone with an intellectual high-ground.
Your past comments belie an intellectual poverty so extreme, I'm amazed that you still have the courage to open your mouth in a public setting. Long ago you revealed intellectual bankruptcy. Probably why you cannot defend your point of views. Not helpful.
