Thread: A pillar guides
Old 12-06-2020, 09:42 AM   #26 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Julian, I noted that your best results came from a 17 mm inlet.
I planned to use some thickwalled Coroplast ( 4mm ) and use the built in ribbing to direct airflow, but now see it will be far too small.
I could sandwich the Coroplast till I get the correct thickness, but I see you also had a smaller outlet diameter.
So I guess that won't work.
I wanted to ask if the Gen1 Insight has raised channels along side the windshield like my Civic does.
