Old 12-11-2020, 04:37 PM   #4 (permalink)
aerohead
why
Originally Posted by JulianEdgar View Post
Why would I try to find the exceptions? Most fastbacks generate more lift than squarebacks and notchbacks.
Yes, but why would I try to find these exceptions rather than using as examples those which are most common?
This is a difference that you have just invented. Attached flow is attached flow, whether it is caused by downwash or not. I have already quoted the head of Jaguar aero in support of that, but as always, you believe that you are right and the true experts are wrong.
1) Dimensional analysis of a non-separated flow fastback would provide a reference datum from which to ponder what a subtle difference in architecture can mean to aerodynamic performance.
2) ditto
3) downwash is not attached flow. It is symptomatic of flow separation. You'll get the highest drag, vortex-drag, plus a small, but very low pressure wake, and overall higher drag. To say otherwise is delusional. It may look like a duck, but it doesn't quack like a duck.
4) If your experts are saying otherwise, then they ARE wrong.
