Old 12-16-2020, 04:10 PM   #1180 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
How about the Saturn? Are there any common problems?
The Saturn 1.9L is known to burn oil about at a rate of a quart of oil every 1,000 miles. That is "normal" some will burn more - some less.
The piston rings build up carbon and stick. I've read you can fix it by removing the spark plugs and soaking the pistons and rings with sea foam fuel additive.
Some friends had one. It ran for over 200K miles but was leaving a trail of blue smoke by the time they got rid of it.
The Following 2 Users Say Thank You to JSH For This Useful Post:
MetroMPG (12-16-2020), Xist (12-17-2020)
