Originally Posted by JulianEdgar
To remind you, we're talking about the fact that attached flow can cause drag, something you said did not occur.
My takeaway from Hucho and all the others in fluid mechanics is, that any drag associated with resultant forces pale in comparison to low base pressure aggravated by separation.
Most attached flow drag is associated with viscous shear and its friction drag.
