Old 12-16-2020, 07:01 PM   #6 (permalink)
cRiPpLe_rOoStEr
The material used has to support the structure above and have enough footprint to spread that load to the ground it sits on. If you can get the compressive strength high enough plastic would substitute for cement.
I guess moulding the plastic in a more stable shape, or reinforcing it with some fiber, might also influence its suitability to such use. But even if it won't be the best material for a foundation, might be a reasonable option for other structural components replacing some pieces nowadays usually made out of wood.
