I may have overlooked it, but what material did you use to make the air dam on that car?
Also, I figured I would ask since you have a Mirage too: do you know of a trick to pass the scangauge cable from the OBD port up the side of the dash when using a windshield mount? I took a quick look at it and it looks like I will have to loosen the dash itself and pull it back to make room to get the cable through. I didn't try it because I was short on time but I am now off work until after new years
