Old 12-22-2020, 04:39 PM   #9 (permalink)
Vman455
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
Originally Posted by JulianEdgar View Post
Vman455 told me he used sheet metal for external front air curtains and recorded a drag increase on his Prius - but they gave much better stability when passing trucks.
Yes, this is correct--the sheet metal front ducts by themselves appear to increase drag based on fuel economy testing. But when I compared pressure difference on each side of the car just behind the front wheel arches (at Julian's suggestion--thanks!), I found that the average pressure difference between sides in a 25 mph crosswind was nearly 15% lower with the ducts on. The wing sections seem to be a better solution, and something I'll probably try in the future.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following User Says Thank You to Vman455 For This Useful Post:
JulianEdgar (12-22-2020)
