Old 12-22-2020, 11:25 PM   #12 (permalink)
JulianEdgar
'Idealized' is part of the conversation, so we're talking about 2% cooling systems. No single modification exists within a vacuum.
If we remove 'idealized ' from the conversation ,then we've changed the conversation.
As far as I can see, yes, you're talking about a different conversation. I may be wrong, but I didn't see anything about drag in the original post. Just heat dissipation.
If we're talking overall cooling system efficiency (ie including drag) then I'd add throttle stop testing to pressure testing.
aerohead (12-23-2020)
