Old 12-23-2020, 03:32 PM   #39 (permalink)
JulianEdgar
1) ' The pressure on the rear face of the body, in the separation region, is found to be approximately uniform and equal to the pressure just outside the boundary layer at separation.' P. W. Bearman, Dept. of Aeronautics, Imperial College, London, England, Re: ' Review- Bluff Body Flows Applicable to Vehicle Aerodynamics, Journal of Fluid Engineering, Sept. 1980, Volume 102, page- 265.
I don't think that you can state that wake base pressure reflects body pressures at the end of the vehicle.
There are numerous pressure plots available of vehicles - some show similar pressure in the base area and trailing parts of the body, but many do not. The coloured pressure plots I posted above don't, and nor do the following:
I also had a good look through my reference library yesterday and could find nothing that supports the idea.
aerohead (12-23-2020)
